Group: DynoMotion Message: 12902 From: Colin Fera Date: 3/3/2016
Subject: Kflop step direction break out
Is there an easily adaptable to the kflop breakout board that could be used break out the step/direction pins from the kflop preferably with some kind of isolation?
Colin
Sent from my iPhone
Group: DynoMotion Message: 12903 From: TKSOFT Date: 3/3/2016
Subject: Re: Kflop step direction break out
Hi Colin,
Not that I'm aware of. Most drives already optically isolate the step/dir inputs so extra opto isolation is not usually necessary.
Winford.com makes basic breakout boards for cables. For example:
http://www.winford.com/products/brk2x13.php
On 2016-03-03 10:28, Colin Fera colin.fera@... [DynoMotion] wrote:
> Is there an easily adaptable to the kflop breakout board that could be > used break out the step/direction pins from the kflop preferably with > some kind of isolation? > > Thanks, > Colin > Sent from my iPhone
Group: DynoMotion Message: 12905 From: Colin Fera Date: 3/5/2016
Hey Tom,
The drives do have opto's,  there is some issue with noise at times the drive will step randomly when its otherwise idle but enabled.   Also it will lose or gain steps sometimes.  The output was configured as open collector.
I changed the output to LVTTL and connected the anode to 3.3v instead of 5v and tested for 20 or 30 minutes and didn't see these issues at all.
The drive manufacture recommends 5v+or-10% but the drive seems to work much better with LVTTL outputs. I was thinking maybe if the drive steps on the rising edge and at a fairly low voltage then there isn't much headroom on top of the
What would you advise as the long term solution.  Perhaps a level shifter?
Colin
On Thu, Mar 3, 2016 at 12:36 PM, tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Colin,
On 2016-03-03 10:28, Colin Fera colin.fera@... [DynoMotion] wrote: > Is there an easily adaptable to the kflop breakout board that could be > used break out the step/direction pins from the kflop preferably with > some kind of isolation? > > Thanks, > Colin > Sent from my iPhone
Group: DynoMotion Message: 12907 From: Tom Kerekes Date: 3/6/2016
Hi Colin,
What kind of drives do you have?  Do you have the voltage and timing specifications for them?
Open collector mode should apply the full +5V without issue when sinking low, but when floating high (off) the opto may not be held in the off state.  The output is clamped from floating higher than ~3.8V which still applies ~ 1.2V to the opto.  Most inputs need significantly more than this to turn on.
I don't think your chip would work because it only has very weak continuous drive capability due to the automatic direction sensing technique.  In your case you know the direction so that isn't really necessary.
Maybe this if 8ma is enough to drive your optos.
http://www.ti.com/lit/ds/symlink/sn74ahct541.pdf
On 3/5/2016 7:31 PM, Colin Fera colin.fera@... [DynoMotion] wrote:
Hey Tom,
Colin
Hi Colin,
Group: DynoMotion Message: 12909 From: Colin Fera Date: 3/6/2016
The drives are these: http://www.dmm-tech.com/Dyn4_main.html
Page 30-32 of the manual provided timing diagrams and lists voltage as 5v +/-10%, max freq as 500khz, minimum pulse width 800us and I think the direction setup is 5us if I am reading the timing diagram right.
Maybe some isolators that would also provide level translation.  http://www.ti.com/lit/ds/symlink/iso7640fm.pdf
The drives have 5v supplies built in which could be connected to the output side of the isolator.
Colin
On Sun, Mar 6, 2016 at 1:33 PM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Colin,
Hey Tom,
Colin
Hi Colin,
Group: DynoMotion Message: 12910 From: Colin Fera Date: 3/6/2016
Forgot to mention, I am actually using quadrature mode.
Is the diagram here for quadrature correct?
http://dynomotion.com/Help/StepAndDirection/StepAndDir.htm
I thought that the B phase had the same pulse width as the A phase but was 90 degrees offset.
Colin
Colin
Hi Colin,
Hey Tom,
Colin
Hi Colin,
Group: DynoMotion Message: 12911 From: Tom Kerekes Date: 3/6/2016
Hi Colin,
The 5V +/-10% is somewhat vague.   They don't specify at what current and at what voltage it is guaranteed to turn off.  The circuit seems to be an opto LED with a series 270 ohm resistor.    Assuming the LED conducts at 1.4V the required current to drive to 5V would be:
(5.0-1.4)/270 = 13.3ma
Those isolators are only rated to sink 4ma.
I like quadrature mode because it basically eliminates all timing issues of min pulse time and direction setup time.  Quadrature only has 90 degrees of phase difference when moving one direction at constant speed.  When the direction reverses the phase changes.
Colin
Hi Colin,
Hey Tom,
Colin
Hi Colin,
